Perform the following procedure to control link state changes on VLACP ports. By default, VLACP Flap Detect and Damping is disabled on all VLACP ports.
Important
Do not enable VLACP Flap Detect and Damping on Link Aggregation Control Protocol (LACP) enabled ports.
To configure VLACP Flap Detect and Damping on sub-ports, enable channelization. For more information about channelization, see Channelization.
As a best practice, to modify an existing VLACP Flap Detect and Damping configuration, first disable VLACP on the interface.
Configure VLACP Flap Detect and Damping on port 1/3:
Switch:1>enable Switch:1#configure terminal Switch:1(config)#interface GigabitEthernet 1/3 Switch:1(config-if)#vlacp flap-detect enable Switch:1(config-if)#vlacp flap-interval 120 Switch:1(config-if)#vlacp flap-frequency 6 Switch:1(config-if)#show vlacp interface gigabitethernet 1/3 ========================================================================================= VLACP Information ========================================================================================= INDEX ADMIN OPER PORT FAST SLOW TIMEOUT TIMEOUT ETHER MAC ENABLED ENABLED STATE TIME TIME TIME SCALE TYPE ADDR ----------------------------------------------------------------------------------------- 1/3 false false DOWN 200 30000 long 3 0x8103 01:80:c2:00:11:00 ========================================================================================= VLACP Flap Detect Information ========================================================================================= INDEX FLAP FLAP FLAP TOTAL FIRST-FLAP LAST-FLAP DETECT FREQ INTERVAL FLAP TIME TIME ----------------------------------------------------------------------------------------- 1/3 enable 6 120 6 01/03/19 15:11:52 01/03/19 15:12:12
Use data in the following table to use the vlacp command.
Variable |
Value |
flap-detect enable |
Enables VLACP Flap Detect and Damping on the specified port. By default, VLACP Flap Detect and Damping is disabled on all ports. |
flap-interval<10-600> |
Configures VLACP Flap Detect and Damping time interval in seconds. The default value is 60 seconds. |
flap-frequency<3-30> |
Configures the VLACP Flap count permitted during the configured time interval. The default value is 3. |
